Ana içeriğe geç
Neye ihtiyacın var
Videoya Genel Bakış
Bu teardown bir tamir kılavuzu değildir. iPad Mini 6 cihazınızı onarmak için, servis kılavuzumuzu kullanın.
    Son Düşünceler
    • A single Phillips screwdriver takes care of all the screws.
    • Some components are modular, but all repairs will require painstakingly ungluing the glass display.
    • The iPad mini's battery is fastened with repair friendly stretch-release adhesive, but the removal process is marred by additional adhesive on other parts of the battery.
    • Gobs of adhesive hold many parts and cables in place, complicating all repairs.
    Onarılabilirlik Puanı
    3
    Onarılabilirlik 10 üzerinden 3
    (10 en kolay onarılabileni)
7 Yorum
does the ipad cellular version use qualcomm’s x55 or same as iphone 13’s x60 modem?
abdulaziz khalil - Yanıt
Why would I fixit team be so cheap and bought only WiFi model for teardown and not post this info which cellular modem is used ?
peterkor - Yanıt
We need to know the battery mAh == Where is the full written review?
Lindy Xi - Yanıt
The battery specs can be found on the iPad mini 6 device page! It has a 5034 mAh cell.
Carsten Frauenheim -
Umm.. where is the full written teardown with hi-res pictures…?
inwoochoi - Yanıt
Which GPS chip is iPad mini 6 2021 using? What signals and frequencies are supportet? GPS, GLONASS, NAVIC, BeiDou, Galileo, SBAS, and QZSS ? L1/L2/ B1/ E1 & L5/E5a/B2a ? Sony? Broadcom?
Pooh the Great - Yanıt
Hi,
I’ve got a special question because I want to know if the USB-C Charging port can be changed to a lightning charging port? Thank for your help!
Kind regards,
Michael
michael ernest - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 22
Son 7 gün: 131
Son 30 gün: 492
Her zaman: 37,860
