Ana içeriğe geç
PlayStation 3 (veya daha sık bilinen adıyla PS3), Sony Computer Entertainment tarafından üretilen üçüncü ev bilgisayar eğlence sistemidir ve PlayStation 2'nin akabinde devamı olarak üretilmiştir. 11 Kasım 2006'da piyasaya sürüldü.
781 Soru Tümünü görüntüle
Soru Kapandı
Still getting the YLOD
I don't know what I am doing wrong I have pre heated the broad then turned up the heat and when over the chips CPU and GPU then I put new past on and everything and still nothing, SO WHAT AM I DOING WRONG!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
ericambrose32, first you do need to remember that this will only work id your YLOD is caused by solder fractures and if they are not to extreme. Reflowing any board with a heatgun is not an exact science and as such does have a certain amount of failure. The proper fix for this would most likely be a professional reball. Anyhow, the biggest reason for failure to reflow is not enough consistant heat. There is a fine line between reflowing and absolutely melting the solder, so one needs to be aggressive without going over board. If nothing else, get a couple of temperature probes and see what heat you generate. Looks at your previous question about the temperature ranges. Right now it seems you got not much to loose since it is not working anyhow. Follow the guide from here and keep on trying. If at first you don't succeed....:). hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
10 Yorum:
Well I have almost given up on it, but I am still trying I posted about the heat sink straps and I striped a little bit of it off.
tarafından
When you say "striped a little bit of it off" what are you referring to?
tarafından
the first 3 threads off of the screw.
tarafından
Any damage to any other part? what happened that you stripped the thread:-)?
tarafından
No. It was getting tighter till I was not able to turn it, but then it stated turning some more ,but then I back it out.
tarafından
5 tane daha yorum göster
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 568
