Ana içeriğe geç
6. nesil iPod nano için onarım bilgileri. Eylül 2010'da piyasaya sürülmüştür. Model Numarası: A1366.
Please help me! WATER DAMAGE
I accidentally washed My iPod in the washing machine and it wouldn't turn on. I put it in a bag of rice for 24 hours but nothing happened. when I took it apart the lcd fell apart. Please tell my how to fix it
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
chanan, It seems this happens a lot. Here is my answer to the same question from a different person "The first step you should do is to disassemble your iPod. Use this guide to help you out. After that clean the iPod thouroughly by following this general guide. You a high grade isopropyl alcohol. Once you are sure the logic board, connectors (do not forget the dock connector), and cables are clean replace the battery. You can get it at places like this. Once you have all this accomplished, reevaluate for any residual (if any ) damage. In your case, you may have to replace the LCD as well. Follow this guide for that. Remember that this model is a PITA to work on but not impossible to fix. Hope this helps, good Luck.
here and here and one more here
iPod Nano 6th Generation Ön Panel Düzeneği Görseli
Kılavuz
iPod Nano 6. Nesil Ön Panel Düzeneği Değişimi
Zorluk:
Orta
35 minutes - 1 hour
iPod Nano 6th Generation Anakart Grubu Görseli
Kılavuz
iPod Nano 6. Nesil Anakart Grubu Değişimi
Zorluk:
Orta
30 minutes - 1 hour
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Yanıtını ekle
chanan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 10
Her zaman: 9,656
