Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
20 Soru Tümünü görüntüle
Sleep/Power button doesn't work
Hello!
I have a iPhone 5 the device never drop.
But today the right side of sleep/power button stopped working (only on right side,the left side of the sleep/power button work)
How I fix it?
Try Contact Cleaner Spray?
Thanks!
Bu iyi bir soru mu?
Puan -1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I can also confirm that this is a common issue and will be covered under your apple warranty.
I have had two iPhone 5's replaced by apple for this very reason, they must have used a weak part as a lot of people are having the same issue.
Go to the following page and start your apple service requesthttp://www.apple.com/support/iphone/cont...
The following is where you need to click.
"Apple Support" then "Get Started"
"Service requests or troubleshooting" then "Buttons not working" then select "Sleep/Wake Button"
Within 2 days a package is sent and once you have sent it off a new iPhone will be on its way back to you within 5 days, thats right a new iPhone 5 for a button issue. Must be costing them a lot of money.
Anyway let me know how you get on.
Cheers
Brendan Mills
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
I do not live in the USA.
I can not send the device to Apple Store.
If I use spray cleaner contacts that can help?
tarafından
I don't live in the USA either, Apple will give you an option of how they can get it replaced. They must do in order to fulfil their legal requirements for the warranty.
I would never touch anything under warranty, but if you really want to then, it not a question of cleaning the button, the actual push switch will be faulty and will need to be replaced. This is the guide you will need to complete in order to replace the power button, iPhone 5 Audio Control and Power Button Cable Replacement
tarafından
Yorum Ekle
En Yararlı Yanıt
I've seen this on several iPhone 5's so far. Usually the button still "clicks" fine, but just doesnt function correctly. If its still under warranty, you can take it to an Apple store and they will replace. Its a part issue. If its not under warranty for some reason (they come with 1 year)....Then you need to replace the power/vol/mute flex cable. This is about a $8 part online just about anywhere. Its rather difficult to replace.... it takes time and patience to install correctly. But it will resolve the issue as well.
Hope this helps!
Puan 1
Yorum Ekle
Yanıtını ekle
Avior sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 36,826
