Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
iPhone 5 Front camera dont work after screen replacement
Hi everyone, i did a screen replacement of my iphone 5 but after that the front camera doesn't work anymore, i tried to reseat the connector but steel not working, could i screw up the logic board? help!!!
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
I have two like this and it is board damage at the very edge of the board.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
you probably damaged the front camera flex cable. they are very fragile, replace and your camera will be fine
iPhone 5 Front-Facing Camera and Sensor Cable Replacement
Puan 1
1 Yorum:
should it matter if the earpiece and the brightness adjuster still working?
tarafından
Yorum Ekle
i bought a replacement camera from ifixit as well and did the replacement, they don't work. the camera when turned on just gives a small glimpse of what it sees and then freezes, do you know what the problem is?
Puan 0
Yorum Ekle
It seems you break the cable of front-facing camera. Can you describe more detail about the front -facing camera.
Puan 0
Yorum Ekle
Does the back camera work? Some times if back cameras broke it won't cycle to the front camera
Puan 0
2 Yorum:
Jess do you mean damage around were the camera contacts to the motherboard?
Fire up a few pics and Jesus can compare
tarafından
Yes--there is a row of very tiny SMD components between flex connector and board edge.
The other had damage to another tiny component on the other side of the connector. I will try to post a pic later
tarafından
Yorum Ekle
Yanıtını ekle
Jesus Ruiz sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 6,759
