Ana içeriğe geç
Sixth iteration of Apple iPhone, announced on September 12, 2012. Repair of this device is similar to the previous models, requiring screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Black or White.
3365 Soru Tümünü görüntüle
iPhone 5 screen is loose
My screen protrudes too much from the rear case assembly because the rubber/plastic (?) material which originally lined it on the left side has separated, and as such it is free to move around in that area.
I am wondering which options exist for replacing or repairing this issue, preferably without buying a whole new display assembly. Do I just need to apply adhesive to the side of the glass? Better yet, can I buy a new glass and swap it for the one of the assembly I have right now?
Yanıtlandı! View the answer Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
If it is not affecting your phone other than moving around a bit, I would just leave it. Replacing just the glass is near to impossible since it is heated onto the LCD. You could try buying a case that secures the phone together, that way you wont be letting dust and dirt in there.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I would recommend to either get a case that would not allow it to move. Like Dustin said you cannot just buy the glass and replace it that way. It requires very expensive equipment to do that. I would also look up your serial on Apple's website and see if it's under warranty. If it is, then schedule a Genuis Bar appointment at the nearest Apple store to see if they would swap out the part or phone for you.
https://selfsolve.apple.com/agreementWar...
Puan 1
Yorum Ekle
If the phone is within a year you can take it back to apple for an exchange. I'm sure they will give you a refurb but its better than what you are doing now.
Puan 0
Yorum Ekle
Yanıtını ekle
Marcus McLean sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 13
Her zaman: 22,739
