Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
iPhone 5 screen is loose
My screen protrudes too much from the rear case assembly because the rubber/plastic (?) material which originally lined it on the left side has separated, and as such it is free to move around in that area.
I am wondering which options exist for replacing or repairing this issue, preferably without buying a whole new display assembly. Do I just need to apply adhesive to the side of the glass? Better yet, can I buy a new glass and swap it for the one of the assembly I have right now?
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
If it is not affecting your phone other than moving around a bit, I would just leave it. Replacing just the glass is near to impossible since it is heated onto the LCD. You could try buying a case that secures the phone together, that way you wont be letting dust and dirt in there.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
I would recommend to either get a case that would not allow it to move. Like Dustin said you cannot just buy the glass and replace it that way. It requires very expensive equipment to do that. I would also look up your serial on Apple's website and see if it's under warranty. If it is, then schedule a Genuis Bar appointment at the nearest Apple store to see if they would swap out the part or phone for you.
https://selfsolve.apple.com/agreementWar...
Puan 1
Yorum Ekle
If the phone is within a year you can take it back to apple for an exchange. I'm sure they will give you a refurb but its better than what you are doing now.
Puan 0
Yorum Ekle
Yanıtını ekle
Marcus McLean sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 22,825
