Ana içeriğe geç
The Droid Razr is an Android-based, 4G LTE-capable smartphone designed by Motorola.
60 Soru Tümünü görüntüle
Problem with wifi signal level after repair (changing LCD display)
Hi,
after replacing the LCD unit of my Razr XT910, I got a problem with very low wifi signal level. Is it possible that I have damaged the wireless antenna ? The GPS is not connecting, too. However, it was not connecting before I replace the LCD. I am still in doubt where it is really positioned the wifi antenna.
Best regards,
Heron
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
With little documentation out there, and not having that specific model on me I looked at a couple of teardowns and images of the parts. There is two antenna's I can see on the mid frame (rear housing). One near the top, the other near the bottom. The larger of the two will most likely be cellular.
There is also a possible antenna on the LCD flex cable. I would generally think its a IC but from lack of traces leading to it, just can't be.
As for the GPS, antennas are usually in the controller for it.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Heron Carvalho sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 4
Her zaman: 1,198
