Ana içeriğe geç
The current line of iPod touch comprises seven (7) different generations.
2619 Soru Tümünü görüntüle
I have a rock stuck in earphone plugin?
There is a rock stuck in earphone plugin on my iPod and i cant get it out. What do i do?
Bu iyi bir soru mu?
Puan -1
2 Yorum
Try using a sewing needle to pry it out.
tarafından
It may require a pair of sewing needles.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You're better off just replacing the jack on the iPod instead of digging the rock out. The part is dirt cheap, so it makes no sense to dig the rock out to me.
Until I know what iPod you have, refer to this link to find the iPod you have.
Bu yanıt yardımcı oldu mu?
Puan 1
4 Yorum:
Can i safely take the iPod apart?
tarafından
yes just follow a repair guide
tarafından
If you tell him which generation you have he can direct you to a teardown. + Ralph
tarafından
Taking the iPod apart does not fix the problem, the rock is inside a jack which is covered on all sides except one. I suggest you buy the new part first if you are planning to replace the jack. It may not be an easy part to get.
tarafından
Yorum Ekle
Yanıtını ekle
dillon wilson sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 3,327
