Ana içeriğe geç
The Gateway NV52 was released in 2008. It is similar to the MS2274 and NV5207u models.
15 Soru Tümünü görüntüle
My computer gets really hot and loud?
Ok, so i have a NV52 laptop. Whenever I use it, it gets really hot, the charger also gets hot, and it really hurts if I touch it. It also gets very loud, if i'm watching a movie or something, I can barely hear anything they say, because of the loud noise my computer makes. I cleaned the fan inside once and it was quiet for few days, but then it started again. I tried cleaning the fan again, and it didn't work. I always put my computer on hard surface, never on my lap or a pillow or anything like that. What do I do?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Carlos, the "gets hot" and gets very loud" leads me to believe that you are having a bad fan. Since you already cleaned it, I would suggest that you once more disassemble your laptop, and clean all the air vents properly. Replace the fan and clean the heatsink. You also want to apply new thermal past to the CPU/Heatsink. Hope this helps, good luck.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
If your computer gets hot and very loud, perhaps take a look at your fan carefully. I would recommend for you to disassemble your laptop and perhaps insert a new one. However, prior to do so, make sure you clean all the air vents properly.
Here is a link that can help you replace the fan for the Gateway NV52.
Gateway NV52 Cooling Fan Replacement
Hope this helps, good luck!
Puan 1
Yorum Ekle
Yanıtını ekle
Carlos sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 388
