Ana içeriğe geç
The Brother MFC-490CW is a all-in-one color inkjet printer released in July 2009.
17 Soru Tümünü görüntüle
I still receive the error message "Paper Jam" after removing paper
To clear the error message Paper Jam after you removed the jammed paper, If you still receive the error message, a small piece of paper may be stuck inside your Brother machine.
Move the print head and remove any ripped paper
- To prevent damage to your Brother machine, try not to touch the internal part when removing the jammed paper.
1.Open the scanner cover.
DO NOT touch the encoder strip. The encoder strip is a clear plastic strip in front of the white vinyl band. If the encoder gets markings or debris on its surface, it may cause other problems.
2.Check the position of the print head.
•If you found the print head at the left hand side or center of the platen area, go to STEP 3.
•If the print head is in the right corner as shown in the picture below, hold down Stop/Exit until the print head moves to the center.
3.Unplug your Brother machine from the AC power outlet (electrical socket).
4.Gently move the print head using your fingers to take out any paper remaining in this area. To remove the small pieces of paper, you can use a pair of tweezers.
Gently move print head
The ripped paper may be very small. Using a flashlight will help you to find the ripped paper.
5.Close the scanner cover and plug the power cord back into the AC power outlet (electrical socket).
If you still receive the error message Paper Jam, or if no debris was found, the encoder strip will need to be cleaned.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
If you opened either the scanner cover or the paper jam cover to gain access to the paper, make sure the covers are securely closed. If either covers are still open, the device will not remove the paper jam error until the cover is closed.
Bu yanıt yardımcı oldu mu?
Puan 0
1 Yorum:
my printer brother t-300 paper jam error but not paper jam
tarafından
Yorum Ekle
Some of you may be dealing with the paper jam issue due to the technical problems in the cartridge. so make these changes into the printer and then it will start working fine.
  1. Let’s open the paper tray, is there something stucked in the tray? if yes! you need to remove it.
  2. Please Open the front panel, and check if there is any piece stucked inside the printer.
  3. Check the backside of the printer.
  4. Remove the broken paper from the output tray as well.
After cleaning your printer, you will get rid of brother printer paper jam error with no paper jammed problem.
Puan 0
Yorum Ekle
Yanıtını ekle
George Kielpinski sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 11,463
