Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
20 Soru Tümünü görüntüle
Microphone quiet/muffled when using front-facing video
Hi All! What does it mean when the microphone works fine when using the back video camera, but when you switch to the front camera the microphone input is quiet and muffled?
If you Google the issue it's apparent that lots of people have experienced this, but there doesn't seem to be a clear solution.
Thanks!
John
Bu iyi bir soru mu?
Puan 5
2 Yorum
Hi guys,
I just faced with this problem today morning. The customer is a girl, with iPhone 8 (black), no scratch, perfect condition. Not that dropping kind of customer :)
Opened the phone, perfect, no liquid, no missing shields, no mixed screws, I think this never been opened before.
I did not even try to clean the mesh because it was clean already, just replaced the frontcam unit and baaam... working fine.
I never will understand this, the camera was in perfect condition just like the phone, reportedly was not dropped, so the mic just stopped working, weird.
tarafından
Go to settings/camera and make sure record stereo sound is on.
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
IMO it means the front mic part of the front camera flex cable is not *recording* sounds like it should. It could be that A/ the mesh covering the ear speaker and front mic is clogged, or B/ the cable is improperly seated, or C/ the mic or cable carrying it is damaged.
I'd start with A/, pierce the mesh of the ear speaker with a fine needles ~3 times in the middle of the mesh. Don't let it in more than ~1mm to avoid disturbing anything in there. Then test the mic.
B/ If no improvement, I'd use this guide until step 11 to disconnect then reseat the front camera cable. This may help, although not very likely.
C/ Change the front camera flex cable following the guide here above all the way to the end.
Note: if issue is a clogged mesh, it can be changed using that same guide here above to remove the front cam flat cable (like in option C), after which push the mesh in, from the outside towards the inside of the screen using a flat plastic tool. Get a replacement mesh from eBay or just peel off the top layer and put the rest back in. It's a bit of a pain to replace that mesh and there is always that inherent risk to every repair to damage the phone or screen.
Replace a front camera and sensor cable compatible with the iPhone 5 smartphone. Includes the front facing camera, secondary microphone, ambient light and proximity sensors. Part #821-1449-A, 821-1449. Görseli
Ürün
iPhone 5 Front Camera and Sensor Cable
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
It's a bit detailed in case someone with less experience reads it and wants to follow the troubleshoot.
tarafından
Thanks Rany, I appreciate it! I was posting for a friend, so I'll let him know the info and let you know how it goes.
tarafından
Welcome! Never had this exact case before, so I'm guessing.. but that's where I'd look. Then if it doesn't solve it, would check the sound circuit on the board. But "muffled" pointed me towards a clogged mesh.
tarafından
In my case, i disabled the “Record Stereo Sound” in Setting > Camera. Guess theres some bugs still in ios14
tarafından
Yorum Ekle
En Yararlı Yanıt
Looks like noise cancellation is "on" in your settings.
Go to settings>General>Accessibility. Right at the bottom is Noise Cancelation and my guess is that it's "on". Turn it "off" and Bingo, you'll be hearing sound on recordings again.
Puan 3
2 Yorum:
UGH. Didn't work. It was "on" and I toggled it off, but still nothing. Can't figure it out yet.
tarafından
same have this issue and nothing can be done
tarafından
Yorum Ekle
Try this
Settings > Camera> turn off Record Stereo Sound
The muffledness went away for me
Puan 1
1 Yorum:
worked for me thank youu
tarafından
Yorum Ekle
https://www.amazon.com/gp/product/B07FFL...
Update (01/16/2019)
try this one. They claim this works.
Puan 0
Yorum Ekle
I have the same issue and thought it was the phone. Downloaded a third party camera app for better quality video and low and behold, it fixed the front mic issue. if i use the iPhone camera app its muffled. if i use the other app it works fine. so weird….
Puan 0
1 Yorum:
I’m having the same issue, on Snapchat it records fine, but on the iphone “camera” front facing the sound goes in and out all muffled, I been testing it and seems like it’s using all 3 mics. But it isn’t clear or loud. It’s muffled and a lot of back static
tarafından
Yorum Ekle
Yanıtını ekle
rdklinc sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 25
Her zaman: 145,803
