Ana içeriğe geç
A handheld, user-friendly electronic label maker manufactured by Brother.
2 Soru Tümünü görüntüle
My unit wont turn on
I already replaced the ac adapter with a new one and the machine still won't turn on. I don't use the unit with batteries at all as it drains the batteries very quickly.
the screen remains blank. any suggestions?
Update
so i tested it out today with batteries and the unit turned on! Which makes me think something is wrong with the metal prong that attaches to the adapter. I also tested my adapter with my dvd player and it worked. So now I know what the problem is but can this be fixed? It looks fine to me; is not loose or broken.
Bu iyi bir soru mu?
Puan 1
2 Yorum
i have the PT-D600 that wont turn on, or do anything at all..
tarafından
Brother pulled an Apple on me and reversed the polarity on their 9v adapter. I made an adapter adapter (I call it an unadapter) so the center pin is the negative and now my generic 9v ac adapter works.
Pay attention to the (+)-c-(-) symbol beside the voltage requirement.
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
noosheen, start by opening it up using these guides. Then use a multimeter and plug your power adapter in. Measure the voltage on the solder points of the jack on the logic board. It is possible that it has broken off, that you have colder solder joints or that the jack itself has failed.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
REFER TO THESE it seems
SOMEONE MAY HAVE DROPPED IT. SOMETHING SEEMS BROKEN.
Brother PT-D200 Troubleshooting
Puan 1
Yorum Ekle
Remember the power adapter must be center pin negative, most adapters are center pin positive, look closely where the adapter plugs in.....there is a small symbol that shows center pin negative
Puan 1
Yorum Ekle
I have bought 2 adapters and both do not turn on the machine. I have also put in 6 brand new batteries and still won't turn on.
Puan 0
2 Yorum:
I just had this problem too. It worked great last time I used it. Plugged it in this morning and it won't turn on with the adapter. I put in batteries, still won't turn on. Any solution?
tarafından
Same problem for me too.
tarafından
Yorum Ekle
Yanıtını ekle
noosheen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 6
Son 7 gün: 28
Son 30 gün: 92
Her zaman: 6,246
