Ana içeriğe geç
Updated in March 2008 with 802.11n Wi-Fi support, the AirPort Express A1264 is a compact and portable wireless network device.
Fix for AirPort Express A1264
Hello,
I have an airport Express a1264, it sometimes gives me a few seconds a green light, and then a orange one. I think then it's booting. But after 5 seconds it stops. When I try it again, then it isnt showing me any sign of life. Maybe it's the power supply. Please help me.
Kind regards
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
First give this a try: Resetting an AirPort base station FAQ.
You may need to reconfigure the AirPort. Download the AirPort Utility from here: Support downloads
Bu yanıt yardımcı oldu mu?
Puan 2
4 Yorum:
Hello,
I've done it several times, but the airport is not showing me a light.
I really think it's a hardware failure.
tarafından
Can you access it via the Ethernet connection with your Mac running the AirPort utility?
tarafından
I'm sorry for my late answer. But no, nothing works, it doesn't show up.
tarafından
Ouch! Thats not good ;-{ Sounds like its time for a new unit.
tarafından
Yorum Ekle
Based on your comments on the status LED, most likely, the power supply in the base station has failed.
Ref: AirPort base stations: About AirPort base station status lights (LED)
One possible means to try to revive it would be to perform a "factory default" reset on the base station. You may need to try this a few times. If this fails to solve the issue, you will need to replace your base station.
Puan 0
Yorum Ekle
Yanıtını ekle
Diederik De Coninck sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 18
Her zaman: 2,470
