Ana içeriğe geç
Jawbone MINI JAMBOX, küçük bir boyutta kaliteli ses sunan, taşınabilir ve Bluetooth özellikli küçük bir hoparlördür.
Music not playing through bluetooth?
My phone is paired with the MINI JAMBOX over bluetooth, but I cannot play music. However, I can play music over the auxiliary cord, but not over bluetooth. Whats going wrong?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 4
Yorum Ekle
6 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Have you tried a bluetooth reset or a software update? Here is a link to the soft reset: Jambox Reset and here is a link to the software update mytalk.jawbone.com
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
Another common issue with the JAMBOX MINI is "phantom auxiliary" connection. Your JAMBOX thinks it is connected over auxiliary, so you tries to play audio over that connection instead. Check if there is any blockage in your auxiliary port and take a look at our bluetooth troubleshooting page here. If you think this might be the issue, you should follow our USB / auxiliary port replacement guide here.
Puan 0
Yorum Ekle
Be sure that the audio cable that you can use to physically connect your phone to the audio jack of the JAMBOX Mini is not plugged into the JAMBOX Mini. When the audio cable is plugged into the JAMBOX Mini's jack, it won't play via Bluetooth. Once you unplug that jack, the JAMBOX Mini will play the Bluetooth audio.
Puan 0
Yorum Ekle
I had the same problem, just make sure NO CABLES are connected to your JamBox at all
Puan 0
Yorum Ekle
I have my Bluetooth connected to my subwoofer and it's saying it's connected at the top but I don't hear any music and I'm not really good and connecting
Puan 0
1 Yorum:
How can I connect my Bluetooth and hear the song at the same time so I can hear it through my radio.
tarafından
Yorum Ekle
My new jawbone jawbox didn't work, cause I can't hear the sounds on my speaker
Puan 0
Yorum Ekle
Yanıtını ekle
Noah Sadler sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 5
Son 30 gün: 30
Her zaman: 27,207
