My line output is periodically failing, any suggestions?
Seems like the line output jack is failing or has a bad connection. Does anyone know of a way to replace it?
thanks!
kiki
Bu iyi bir soru mu?
The OP-1 is a portable music workstation incorporating a synthesizer, sampler, sequencer, multitrack recorder, drum machine, mixer, and controller. It was released in 2011.
İtibar: 1
thanks!
kiki
I had the same thing happen too. You can pop open the bottom and take the board out and resolder the jack, but if that doesn't work you just gotta write to teenage engineering and ask to buy a new output board from them or better yet hopefully its under warranty. Its super easy to replace. Theres a guide right here. Teenage Engineering OP-1 Connector Board Replacement
Good luck!
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 364
