Ana içeriğe geç
Repair guides and support for riding, or ride-on, mowers, also known as lawn tractors, of all types used in tending large tracts of land.
20 Soru Tümünü görüntüle
Mower deck not engaging
i have husqvarna model EZ5426BI mower deck will not engage. Just had the mower serviced than was mowing the lawn and IZT belt broke and was replaced and found the Deck belt had crack so I replaced it and now the deck will not engage
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
Generally speaking, when it works until you fix it, you should go back and double check the work you did. Probably got the deck belt routed wrong - go back and make sure you are on the right side of every guide and pulley.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
You might want to check you ingagement lever and see if the cord that goes from the lever to your deck is broke
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Bhagwanji Gosai sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 80
