Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
Soru Kapandı
LCD display horizontal lines
So I replaced the screen of my iphone a couple of days ago, thinking it'd fix everything and such. Didn't do it correctly and I wonder if I broke the cable in the process or if it's a motherboard/connector issue because the screen has been flickering, horizontal lines and the icons on the screen are 'doubling'. So...would a new screen assembly do the job or do I need a new logic/motherboard?
Something like this https://instagram.com/p/BDV-DaOPgFSG1NQQ...
https://instagram.com/p/BDV-K7CvgFeNxhYd...
Additional: setting it to high brightness made it go dark
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
2 Yorum:
this is normally:
damaged connection
damaged connector
damaged screen
or a lose connection
tarafından
How do I tell the difference? What should I examine? I mean, maybe I just bent the cable, but...
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
does it do the same thing with the old lcd?
Bu yanıt yardımcı oldu mu?
Puan 0
2 Yorum:
Well, the original one had water damage and it's been somewhat similar as in unresponsive but since I 've removed the screens many times maybe I damaged the connector pins. I don't know. I tried rubbing some alcohol ( disinfectant) on the connector but to no avail. Perhaps I need to replace the logic board/ motherboard?
tarafından
if you have to replace the login board, it will be to expensive, might as well get a used one on craigslist or ebay.
tarafından
Yorum Ekle
Almost certain you will have to replace screen - avoid cheap replacement - try to get at least OEM from somebody reliable (Full OEM is preferable)
Puan 0
1 Yorum:
I should have tested the screen before installing so I'll never know if it's a defective screen. But I know it's not an OEM. I'll keep that in mind. Though, could this be a sign of a water damaged logic board?
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 291
