Ana içeriğe geç
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 Soru Tümünü görüntüle
Soru Kapandı
What do I need to buy to add a 3.5 HDD
Hello,
I own an iMac 27" 2011 that I bought with a single 256 Gb SSD.
I opened the iMac and noticed that the SSD is actually located under the optical drive and that there is a large empty space in the middle (where the 3.5 HDD should reside).
So, excepting a 3.5 drive, what would I need to buy (and from whom ) to be able to add a 3.5 HDD in that empty room ? (Brackets, power and data SATA cables, heat sensor cable ?)
Thank you for your reply.
Bu iyi bir soru mu?
Puan 0
2 Yorum
Can you identify your iMac model number? Use the link below on how to do this:
https://www.ifixit.com/Info/ID-your-Mac
tarafından
Hi Ben,
It is a 3.4 GHz (Core i7) iMac Intel 27" (EMC 2429)
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
ive used a 1TB western digital drive for mine and used this guide to make the install.
iMac Intel 27" EMC 2390 Hard Drive Replacement
HDD
http://eshop.macsales.com/item/Western+D...
vids available on youtube for guides also.
Bu yanıt yardımcı oldu mu?
Puan 1
2 Yorum:
Hi Alfie,
Thank you for your answer but this is not what I asked.
I do not need a guide and already bought the Western Digital drive.
Now I need to know where I can buy the missing parts for mounting the drive (bracket, power and SATA cables).
tarafından
thanks for replying, hope this helps as ive used this site below. but ive also used ebay when out of stock and used the correct terms to make searches easier.
sata cables
http://www.welovemacs.com/9227579.html
power cables
http://www.welovemacs.com/applecables.ht...
3.5" IDE/ATA Internal Xserve Hard Disk Drives w/ Carrier
http://www.welovemacs.com/ap3idinxshad1....
tarafından
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 3
Her zaman: 40
