I can barely see the screen
I can barely see the screen and adjusting it makes no difference
Bu iyi bir soru mu?
Bu iyi bir soru mu?
shawn sounds like your backlight has failed. Most common cause for that are bad capacitors. Your monitor does not have a separate inverter but it is part of the power board. Start by disassembling the monitor and take a look at the boards and the caps. Check for bulging or leaking caps. Post some good images of your boards with your original question. For that use this guide. Since I only have the assembly instructions, substitute the assemble with disassemble
Bu yanıt yardımcı oldu mu?
I went ahead and tore it apart right after posting the question and not one of the caps had much for capacitance,they was toast.
Did you replace those?
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 12
Her zaman: 541
