Ana içeriğe geç
Repair information and guides for the Apple iPhone 5c that was announced on September 10, 2013. Model: A1532, A1456
20 Soru Tümünü görüntüle
ear speaker not working after replacement
hi guys, im having real difficulty fixing this iphone 5C, the ear speaker isnt working so naturally i thought speaker stuffed with dirt and replaced it. this didnt fix the issue. then i replaced the flex cable underneath the speaker. still not working. then i made sure the contacts were clean and touching eachother perfectly. still no noise from the speaker. can anyone help me please? is it logic board related? a very strange issue which i have exhausted all repair scenarios. thank you guys so much in advance :)
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
Yorum Ekle
3 Cevap
Filtre ölçütü:
Hello Ryan,
A coupe of things. In my experience I've found mic and speaker issues to be either a software issue or dirt and debris in the mic or speaker ports (the grill in the screen). You should be able to see light through it. Outside of that you have done most everything you can do. Recheck the camera flex connection to the board, one hair can cause a problem
Good luck,
Holger
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Hi Ryan,
Did you use a new front camera flex? If so, you should try using the cable from another iPhone 5C, and make sure the proximity sensor isn't getting caught up underneath. Then of course, restart the device.
There are issues that can occur on the logic board, but they are very rare, at least from what I have encountered.
Puan 0
1 Yorum:
hi guys, grill is brand new so no dirt obstructing the passage of sound, yep replaced the camera flex and speaker unit but still no sound. beginning to think it maybbe software related, although that seems strange.. Thanks again
tarafından
Yorum Ekle
Did you manage to sort this problem? I have came across this a few times
Puan 0
1 Yorum:
i'm having the same problem with the ear speaker not working after screen replacement on my wife's 5c. I actually swapped out camera/speaker and flex cables from another 5C that i knew worked and it still wouldn't work. Right now my wife just has to use her speakerphone all the time. Any more ideas on what to do here? When you say software problem, what can be done here? I read on another site where it might work after wiping the phone and restoring. Any ideas would be appreciated. Thank you ALL!!!
tarafından
Yorum Ekle
Yanıtını ekle
Ryan sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 489
