Engine will not turn over
After replacing my fuel pump, my vehicle started up. But then the next day nothing. Did not turn over. When i attempt to start it i get a clicking sound.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
Hi,
Have you checked your battery cables are securely connected and that the battery is not flat?
Usually a clicking sound is the starter solenoid engaging but there is not enough power for the starter motor to turn over.
Bu yanıt yardımcı oldu mu?
You either have a bad starter,battery or alternator. Or you just have a bad ground on your fuel pump ground.
Try jumping the car and or tapping the starter with a hammer
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 563
