Ana içeriğe geç
Apple iPhone 5s, 10 Eylül 2013 tarihinde duyuruldu. Bu cihazın tamiri, daha önceki modellerinkiyle benzerdir; tornavida ve plastik açma araçları gerekir. GSM ya da CDMA olarak, 16, 32, 64 GB kapasiteli Gümüş, Altın ve Uzay Grisi renklerinde mevcuttur.
3530 Soru Tümünü görüntüle
Data Recovery Broken iPhone
Somebody please help! I recently dropped my iPhone into water and when I pulled it out, it was black and the dot next to the front facing camera was red. I haven't backed up any photos since March and I really need the pictures I have taken since then. I've tried software to recover them, but most won't recognize my phone when I plug it into my PC. How can I get it to recognize my iPhone? I seriously need those pictures. Somebody please help!!!
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
5 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi there,
Tom Chai is right, in order to access your data/photos, the phone has to be semi-functional.
Water damage can be pretty nasty; it causes corrosion on the boards and shorts your circuits. Your best bet is to read and follow the steps on these guides in order to bring your phone to life enough to recover the photos: Repairing iPhone Liquid Damage
Electronics Water Damage
Good luck!
Bu yanıt yardımcı oldu mu?
Puan 4
Yorum Ekle
En Yararlı Yanıt
Repair the original phone to the point that it can boot up, unlock and connect to PC via USB, or have wifi so you can back the data up through wifi. Other than that, nothing else can bring back the data.
Puan 4
1 Yorum:
i agree with Tom ... unfortunately if you cannot the the original logic board to work, the data inside is lost :(
tarafından
Yorum Ekle
Can you connect your old phone to your PC with USB now? If you could, maybe you could try to use data recovery software to help you to recover your data, including photos, contacts, etc, from your phone without any backup. if you are a iPhone users, read this article to learn how to recover data from water damaged iPhone, while read this to know how to if you are a Android phone user, try to find other related article of this website to help you based on your situation!!!good luck to you.
Puan 0
Yorum Ekle
Best advise for future - do a backup! iCloud is super comfy for apple devices.
About extract the data- try this
They helped me ones, after i dropped my iPhone in the pool , phone is dead but i have all my contacts and photos at least.
Puan 0
1 Yorum:
It was written in 2016
tarafından
Yorum Ekle
It may be some hardware related causes, you should check the connector first. Here is a guide on how to recover data from a water damaged iphone. Hope it helps.
Puan 0
Yorum Ekle
Yanıtını ekle
Lydia sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 4
Her zaman: 370
