LCD screen has different color lines across part of screen.
My camera was jarred on a hiking trip. Checked the camera, and all appeared to be OK. However, when taking a picture, I noticed that there were some different color lines running parallel across part of the screen. Also, there are a couple of lines running at an angle that are inside the screen, making it appear that the glass is broken. However, the glass or plexiglass, whatever material, is not cracked. So I'm guessing that something behind the glass was compromised.
If it would be helpful to attach a picture of the screen, I would be glad to send. Did not see any option to attach a picture here.
Bu iyi bir soru mu?
2 Yorum
giveandgo use this guide add images Adding images to an existing question
Do those lines only appear on your pictures or do you see them on the LCD at all times? If they are only on the pictures I'd be looking at issues with the CCD sensor....
oldturkey03 tarafından
Not on the picture, but only on the LCD screen. If that's the case, then could the LCD be replaced to fix my situation?
giveandgo tarafından
