Hello, I just had the same issue this month. The keyboard and the trackpad both stopped working and the only was to fix it was to reboot. I also noticed in the log the message:
"Error: AppleHSSPIController::doSPITransfer NAK received from device" followed every time by
"Error: AppleHSSPIController::doSPITransfer CRC from device was invalid: compu..." and sometimes
"Error: AppleHSSPIController::InterruptOccurred Failed to transfer interrupt data with Err (0x00002eb)".
My MBP Early 2015 was still under warranty and the support told me it was related to a connector between the trackpad and the keyboard formally called "SVC,CABLE,IPD FLEX,HA COPPER,13" MBP" on the invoice. The Apple's Genius ran some diagnostic tests but he show me the results and everything was 100% fine, including the top case.
The repair costs 89€ in France (10€ for the cable itself, 79€ for the hardware fix). Hopefully the repair only takes up to 48 hours (or so they told me, it's been around 5 hours and I'm patiently waiting, I already brought my MBP for other issues and the repairs were fast).
Bu yanıt yardımcı oldu mu?
Oy verildi
Geri al
Puan
I have the same issue, trackpad and power button are still working though.
Did you manage to find a solution?
by aziz tnani
Aziz - I would follow Mayer's recommendation here and get the AppleCare extended if you can (then get it fixed afterwards). Otherwise, it's a very expensive repair as it likely needs a new battery as it likely swelled pressing from below which causes the keyboard to fail.
If you're lucky its still under warranty (within a month of expiring will also work). Apple did have a few battery issues which they did cover under an extended warranty program. But that only works if you didn't get the system wet.
by Dan
Hi Dan and thanks for your answer, my warranty is actually over and i'm living abroad, so no apple service around.
I read in another post that the battery is discharged, the keyboard might work back?? does this make sense?
Can I change the battery myself if I can order one?
How expensive is the repair we are talking about?
by aziz tnani
To replace the battery review this IFIXIT guide: MacBook Pro 13" Retina Display Early 2015 Battery Replacement.
To prove its the battery you can try placing your battery in the refrigerator (not the freezer) to let it cool down. This will reduce the swelling to a point your keyboard should start to work again. If not the keyboard cable maybe damaged which leads to the trackpad from the keyboard from the swelling. Do use a plastic bag to cover your system tightly before you put it in the refg. and if you are in a very humid location let it sit still in the bag for a bit to let it warm up you don't want condensation to damage your system.
You might try looking at Apples web site to see whats near you. Apple has quite a few stores now and they also list authorized service centers as well.
by Dan
I am in Tunisia and I might need to get my laptop to france for a replacement
I am not very confident putting my laptop in the fridge, even with a plastic bag around, if I switch of overnight, unplugged, shouldn't work as well?
by aziz tnani
Show 20 more comments
