Why does my device's touchscreen not respond?
The touchscreen does not recognize any of the key that I press.
Bu iyi bir soru mu?
Cihazların için kılavuz, parça ve yanıtlara hızlı erişim edin
Bu iyi bir soru mu?
This problem may be caused by a faulty digitizer. Try tapping various parts of the screen. If the device is only registering commands at certain parts of the screen, registering incorrect commands, or not registering at all, then the digitizer may need to be replaced.
If the device's screen is cracked, then this problem may not be caused by a faulty digitizer. A cracked screen may indent the structure of the device and unintentionally apply pressure to the digitizer. To overcome this pressure, the digitizer will need hard taps. Normally, the digitizer will respond to soft taps. Replacing the screen may fix this problem.
Check out the troubleshooting guide on this device for more information: TomTom GO 500 Troubleshooting Guide
Bu yanıt yardımcı oldu mu?
problem in the screen. Change the sensor. I had the same problem.
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 17
Her zaman: 2,728
The screen will not activate when touched
Dean Dotterman tarafından
The touch screen does not respond on the left side at all
