Ana içeriğe geç
The Nikon D5200 is an F-mount DSLR camera with a 24.1 megapixel DX-format CMOS image sensor. The D5200 has a maximum resolution of 6000x4000 and is capable of 1080p video recording.
20 Soru Tümünü görüntüle
LCD on but not showing a picture
My D5200 seems to be working just fine other than the fact that it is not showing an picture on the LCD screen. The screen stays grey when turned on but will not show anything (regardless of if I mess with the buttons). I can still take photos and retrieve them from the SD card.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
I have tried hard resets and taking the battery out for 24 hours, no luck.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
sounds like you need a new LCD, follow this guide to fitting a new one
Nikon D5200 Screen Replacement
Bu yanıt yardımcı oldu mu?
Puan 1
1 Yorum:
Hi @jackattack101 ,
To add to @rayeasom's answer, the LCD screen is available on places like Ebay. Here is a link to one supplier. This is not a recommendation, it is merely shown to give you an idea of the cost of the part. http://www.ebay.com/itm/NEW-LCD-Display-...
tarafından
Yorum Ekle
I had the same problem sent it away to Nikon who couldn’t fault itso,
remove the four lcd retaining screws so you can get in and behind the screen there you will find a small electrical connector ( silver in colour and slides onto the circuit board and clips into place)and a larger connectorI found that the larger connector purely by chance wasn’t located and clipped securely in placeyou’ll see what I mean once it’s opened up…
resecured and everything worked as it should reattached lcd screen ,,,never had an issue since
Puan 0
Yorum Ekle
Yanıtını ekle
Jack sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 5
Son 30 gün: 10
Her zaman: 897
