Ana içeriğe geç
Repair guides and support for your Sanyo TV.
Tv powers on then off within a minute
Sanyo DP55441 Tv powers on then off within a minute
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 0
1 Yorum:
@patrick0412could be a power board issue. Open the back of your TV and take a look at the boards. Post some images of what you see with your question. For that use this guide Adding images to an existing question
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Is there any video input to the TV because many new TV's will turn off after about a minute if there isn't any video signal detected. Try connecting a DVD player and play a DVD then turn on your TV. Then if it doesn't stay on then in the correct Input mode in this case either DTV or DVD or even Aux. Whatever input you use the TV should now show it. If it still turns off then it is probably a power issue.
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Yanıtını ekle
Patrick D Doyle sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 117
