Ana içeriğe geç
Sit-on-top lawn mower. Zero-turn radius mower, 50" mower deck, hydro transmission.
20 Soru Tümünü görüntüle
lack of power in transmission drive and mower deck
The mower blades slow down considerably when I get to some thicker grass. It never used to do that. Also the mower does not have enough power to pull itself up a hill.This problem just started to happen recently, the mower was operating perfect most of the summer.
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Don, If mower gets used a lot, may just be belts slipping from wear. If all belts look good, there are few things that can cause your mower to loose power, bad fuel/filter/Air filter, carb. out of adjustment, failing coil running on one cylinder, valve adjustment required, engine worn/low compression, faulty plug, fuel pump starting to fail, etc. Two of the most common are fuel tank cap vent starting to plug(loosen cap to see if engine improves), the other common issue is a dirty carburetor, which will have to be removed cleaned/rebuilt . Good luck.
Bu yanıt yardımcı oldu mu?
Puan 4
1 Yorum:
I had the same problem... I added some LUCAS deep clean fuel line cleaner and it improved greatly
tarafından
Yorum Ekle
Check to see if the transmission drive belt is worn or there is enough tension from the idler pulley spring.
Puan 0
Yorum Ekle
Yanıtını ekle
donbrown24 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 27
Her zaman: 4,506
