Ana içeriğe geç
All-in-one desktop computers from Apple. iMacs were equipped with Intel processors from 2006-2021.
20 Soru Tümünü görüntüle
How do I disable an internal DVD drive?
My internal DVD drive is no longer functioning. I have purchased an external DVD player. I want to disable or remove the existing DVD drive, how do i do this?
Thanks,
Lisa
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
3 Yorum:
Which model is it?
tarafından
Any particular reason in terms of wanting to disable it if it is already nonfunctional? Unless it is creating some unbearable sound or interfering with the operation of your imac.
tarafından
It is recognised and is stoping me intalling something that requsts its use
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
As you did not provide which model iMac you have, you will have to look it up using EveryMac. Once you know your model, find it on iFixit using this page. From there, click the "Optical Drive" link and your done.
Hope this helps!
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
You need to open up the imac, (Ifixit has great tools to do this), and disconnect the wires from the logic board. This should disable the disc drive.
Puan -1
4 Yorum:
This answer is totally useless until you know what iMac it is.
tarafından
i disagree. if you disconnect the disc drive, it will be disabled no matter the model.
tarafından
How are you to disconnect the dvd drive if you don't know how? Based on some MAC ifixit guides Iv'e looked at, something as simple as unplugging the optical can be a pretty tricky maneuver. Besides, your solution doesn't even tell exactly what to do. Opening up the mac and unplugging is obvious. You should take a look at @mayer's profile before you disagree. I did disagree with him sometimes, but I don't anymore! I learned my lesson.
tarafından
I want to disable it in the system somehow not physically its to risky with a mac
tarafından
Yorum Ekle
Yanıtını ekle
Lisa Twitchell sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 2
Her zaman: 697
