Ana içeriğe geç
Repair information, troubleshooting tips, and guides for the sixth iteration of Apple iPhone, announced on September 12, 2012. Model: A1428, A1429
2522 Soru Tümünü görüntüle
Battery not charging after I changed it
Hi, I replaced my old battery with a new i bought here. After I replaced it, Iphone 5 turned on regularly and cherged til 40% . I went to sleep and let it charging, but at morning I found the iphone 5 turned off with 0% battery and now it is not charging anymore and doesn't turn on cause the low battery. I tried 2 different charging cables but it has not changed. can someone help me ? thx.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
What was wrong with the old battery? Was it that it drained to 0% and wouldn't charge or suddenly shut off at certain percentage or stopped working?
If it does not charge a flat battery then the U2 tristar charging IC chip needs to be replaced by someone that offers micro soldering.
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
En Yararlı Yanıt
Hello, change the charge socket first.
You can see how to change it from here
You can get it here
If not, you can try changing the battery
You can get the battery here
You can look at how to do it here
'''If this is not the case then the power integration is also a problem. If you can take a master repairer, you will do it easily.
iPhone 5 Battery Görseli
Ürün
iPhone 5 Battery
$29.99
iPhone 5 Lightning Connector and Headphone Jack Görseli
Ürün
$19.99
iPhone 5 Pil Görseli
Kılavuz
iPhone 5'inizin Pil Değişimi İçin Talimatlar
Zorluk:
Orta
15 minutes - 1 hour
Kılavuz
iPhone 5 Lightning Connector and Headphone Jack Replacement
Zorluk:
Orta
1 - 2 hours
Puan 1
3 Yorum:
thx. the old battery was working wrongly. the percentage gone heavily down using it little bit, or shut off when it seems that was charged.
tarafından
Ah then that's the battery most likely. Have you checked the charging cable if it plugs in fully with no gap and have you tried another charger port?
tarafından
yes, i tried 2 different cables, and cleaned the dust but nothing happens. The strange thing is that after I've changed battery it was charging right, then I don't know what is happened because i found it turned off.
tarafından
Yorum Ekle
Yanıtını ekle
Gianluca De Dominicis sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 95
