Ana içeriğe geç
Behringer Eurolive B212D hoparlör sistemi için cihaz ve onarım bilgileri.
Loud hiss when turned on
Suddenly when I plug in and turn on my speaker there is a loud hiss.
I've tried different power cables and plugging into different outlets.. The hiss is evident whether or not there is a sound source plugged in.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
@townband , Steve , Unplug speaker and use the guide below to disassemble the speaker and spray switches with electro-contact cleaner and remove, spray and reseat connections to see if that gets rid of hissing. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
Behringer Eurolive B212D Güç ve Kontrol Panelinin Sökülmesi
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
I will check it out. Again, the last people to use it were outside and unsupervised.
Who know what they did to it!
tarafından
Steve, Good plan, look for water damage also then, if it does appear to have some on the board use this general guide link below, to to help clean of possible corrosion. Thanks for replying back, good luck with your speaker.
Electronics Water Damage
tarafından
Yorum Ekle
En Yararlı Yanıt
A hiss or buzz in a speaker system usually indicates a poor ground at the speaker . A solder joint may have let loose so that the wires still attached but not a good ground . You'll need to take it apart and check the grounds. Hope this helps
Puan 2
1 Yorum:
Great thought. I will try it out. The last people to use it were outside unsupervised! Thanks.
tarafından
Yorum Ekle
Yanıtını ekle
Steve sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 3,300
