Ana içeriğe geç
Repair guides and specifications on the ASUS Eee PC 1001PX Series released in 2011. This laptop series included a 10.1" display with an Intel Atom N450 Processor.
6 Soru Tümünü görüntüle
How to repair touchpad flat cable?
ASUS Eee PC 1001PX Hard Drive Replacement
Hi guys, firstly I would like to thank who did that guide. It's wonderful. Unfortunately, I didn't find that one before trying it. So, I damaged that flat cable that connects the touchpad on motherboard. The link below is the picture of the damaged cable.
What could I do to repair the damage? If the solution is purchase another cable, what's it?
Many thanks
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
Hi Steffen,
Thank you for the answer, but to buy it by the eBay for who lives in Brazil is more difficult and the sellers don't put more specific data about.
Recently, I took a common ruler and measured the cable width. The picture shows it:
[image|1221870]
I knew it has 12-pin, but I need to find the pitch measuring because on the internet (Aliexpress website) I found more than one pitch measuring, but I think it would be 0.5mm, don't you?
Best regards
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi Diego,
I recently uploaded my repair guide on how to replace the DC jack power (charging socket) on an ASUS 1001PX which also includes the removal of the upper unit/touch pad. You will find it here: ASUS Eee PC 1001PX Charging Socket Replacement
What is actually needed in your case is a 12 pin flat ribbon cable which you easily find online, for example:
http://www.ebay.com/itm/Asus-EEE-PC-1001...
https://www.ebay.com/sch/i.html?_from=R4...
For sure, you can also buy the entire touch pad unit, for example, here: https://www.ebay.com/sch/i.html?_from=R4...
However, if you only need the flat ribbon cable, I suggest that you buy a single ribbon cable that is as long as your old one is and just fold it the way you need it. This should do the job!
Steffen
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Yanıtını ekle
Diego sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 3,633
