Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
iPhone 6s boot loop
I replaced the screen on my iPhone 6s and I followed to ifixit handbook and everything and when I went to power the screen on. I started getting a boot loop. I took it to a repair shop and they said they couldn't find what was wrong. I've tried all the boot loop methods online and I've tried restoring. Nothing has worked. I've been told the mother board has been fried by research and I don't understand why that's so. Nothing looks broken everything looks the way it should
Bu iyi bir soru mu?
Puan 7
4 Yorum
Have you tried changing the battery?
tarafından
Yes.........
tarafından
Maybe there is a short in the LCD connector or light ic or cap
tarafından
The screen that is not original can cause bootloop in this case try another screen
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
I know you said you tried all of the boot-loop suggestions but you don't tell us which ones. So for the record, I'll post some ideas below and tell us if there's anything in there that you haven't tried. That way we'll be able to help a you a bit more.
A few things to consider:
Try these things (if you haven't already) to see if anything helps:
  • Try a hard reset (Home & Power button for 10 secs)
  • Use a genuine Apple Lightning connector
  • Use a genuine Apple charging brick and let it charge overnight
  • Try to connect it to different computers (mac/pc if possible) with an updated iTunes
  • Put the phone in recovery mode (search DFU Mode). Careful, this can reset your data
  • Use 3uTools for putting it in and out of Recovery Mode
  • Use 3uTools to flash the firmware (you can't downgrade)
  • Check the condition of all the flexes (with magnification)
  • Disconnect the Front Camera Ribbon from the logic board and reboot your phone
  • Disconnect the screen assembly completely and see if iTunes will recognize the phone.
Otherwise, you probably have a logic board issue. If you are uncomfortable doing these steps, consider finding a repair shop that does micro-soldering; they can go deeper if the problem is not modular in nature.
Bu yanıt yardımcı oldu mu?
Puan 8
4 Yorum:
Your answers are good as always :)
Also OP exactly how long does it stay on the apple logo then shut off and boot up again? This can tell us what areas of hardware faults we should be looking at.
tarafından
I tried the hard reset. And I just tries the disconnecting the camera. It had about a 5 minute boot loop and just sated on the black screen. Let me ask one question that might help. When I did the screen repair I didn't disconnect the battery. Could that be a problem?
tarafından
Not disconnecting the battery prior to the removal of the screen can certainly cause problems with the backlight circuit.
However, I would be more concerned that you may have caused Long-Screw Damage. That is when you accidentally put a long screw where a short screw would go (usually on the Display bracket). If you didn't keep track of the screws and their placements, this is a real possibility.
At this point, I would consider finding a repair shop that does micro-soldering to properly troubleshoot your phone.
tarafından
I make this tes : Disconnect the screen assembly completely and see if iTunes will recognize the phone. I itune don't detect my iphone is it normal ?
tarafından
Yorum Ekle
It may be caused by the baseband PMU pseudo soldered.
Puan 0
1 Yorum:
What is the baseband PMU and where on the logic board can it be found please
tarafından
Yorum Ekle
Yanıtını ekle
Andre Warren Jr sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 5
Son 7 gün: 29
Son 30 gün: 142
Her zaman: 47,588
