Ana içeriğe geç
2015 Mart ayında duyurulan ve 10 Nisan 2015’te piyasaya sürülen Galaxy S6, Galaxy serisinin önde gelen ürünüdür. Kavisli ekran versiyonu Galaxy S6 Edge olarak bilinir.
487 Soru Tümünü görüntüle
It will turn on but only charge to 50%
My samsung galaxy S6 got rained on, and since then it will turn on and screen looks normal and functions normally, but it will only charge to 50%, but when I unplug it then it dies. Do I need to replace the charging daughter board? If I do, then will the home button finger ID still work?
Bu iyi bir soru mu?
Puan 0
2 Yorum
Both front and back are cracked, between replacing the battery and both front and back glass. Is it cheaper to replace phone?
tarafından
Unless you know how to do a glass only repair, it is usually not worth fixing. If the LCD is black, I would just get a replacement then.
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Sounds like your battery is failing to due liquid. Any time you get liquid on a battery, you want to go with a new one. I would first try a new battery before replacing the daughterboard. If battery fails, then try the board. That should solve any issues you are having with this device.
Samsung Galaxy S6 Pil Değişimi
Samsung Galaxy S6 Daughterboard Replacement
Samsung Galaxy S6 Pil Görseli
Kılavuz
Zorluk:
Zor
45 minutes
Samsung Galaxy S6 Daughterboard Görseli
Kılavuz
Zorluk:
Zor
45 minutes - 2 hours
Bu yanıt yardımcı oldu mu?
Puan 0
Yorum Ekle
Both front and back glass is cracked, and bad battery, with all of these repairs, would it be cheaper to replace the phone?
Puan 0
Yorum Ekle
Yanıtını ekle
Amy ford sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 13
Her zaman: 140
