Ana içeriğe geç
16 Eylül 2016'da piyasaya sürüldü. A1661, A1784 ve A1785 model numaralarına sahiptir. Roze altın, altın, gümüş, siyah, simsiyah ve (Product)Red renk seçenekleriyle 32, 128 veya 256 GB yapılandırmalarında mevcuttur.
iPhone 7 Plus Boot Loop
Hi. My iPhone 7 Plus Keeps rebooting. Boot loop. It Turns on to white apple logo and then shuts off and then turns back on. Keeps doing that repeatedly. I've already tried a restore from my computer and it resets and shows the reset bar but then comes back to the reboot screen. Please Help. Thanks in advance.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 10
4 Yorum
i got this issue its two way one is disconnect the front camera seconed disconnect the home button
tarafından Paylaş
thanks for the advice, worked wonders.
tarafından Paylaş
I'm having the same issue recently restored an iPhone 7 plus and the home home button flex cable must have been damaged i the process is their any way around this.any way to get another functional home button? and advice is much appreciated.
tarafından Paylaş
Look up JC home button. There are 3 or 4 versions. So get the latest one.
tarafından Paylaş
Yorum Ekle
9 Cevap
Filtre ölçütü:
En Yararlı Yanıt
In my experience the most common cause of a bootloop an an iPhone 7 is the Audio IC chip… or rather the lack thereof. This chip will loose some of its solder joints similar to how the touch IC would on the iPhone 6 plus.
Here are some images showing where it is and how to get to it.
Resim
Resim
Resim
The only real way to fix it is to remove this chip, re-ball, and re-solder it back. This does come with some risk and should only be done by an experienced professional.
Also, with some of the later updates of iOS, most iPhones will boot up showing only a black or white screen before showing an Apple logo. This alone doesn’t indicate any kind of issue with your phone.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
i done it ans was very good solution. with thankful
tarafından Paylaş
Yorum Ekle
I have not worked on the 7 plus yet but have had this issue with several of the 6 plus iphones...both of which require board level repair. 1st repair is to replace the Tristar (U2) charging IC Chip and 2nd is to verify proper voltage on NAND (Hard Drive) (Reball has helped).
It could be a software issue as well I imagine but if you are not able to restore, have restored with same issue, or get an error message on Itunes, I think your best bet is to take it to a good repair shop or to Apple if under warranty.
Puan 1
1 Yorum:
It did turn on and boot to the setup screen once yesterday but the home button wasn't working so I couldn't set it up and turned it off to restart it. It started doing it again.
tarafından Paylaş
Yorum Ekle
on iOS 11 you don't test out screens.... replace everything on the lcd and install the new lcd with every screws, close up the phone. then turn on.
note: there are many diff kinds of screens that doesn't work with iOS 11.
if problem continues, check every wiring on the new lcd.... or try putting everything on old screen or working gem screen...
in some cases i hard reset 3 times and plug in the charger.
Puan 1
1 Yorum:
Do you know a reliable supplier that has compatible screens?
tarafından Paylaş
Yorum Ekle
Reinstall the screen with the front camera detached and see if that kicks it out of the loop. The cameras are very fragile and often times when the phone gets hot, It damages the camera and causes that to enter boot loop. If this works, simply replacing the front camera will usually fix the issue.
Puan 1
Yorum Ekle
Please try to use 3uTools to restore your device. Hope it would work for you.
Puan 0
Yorum Ekle
Hi there try this, Press and hold the Power button and Volume Down button simultaneously until you see the Connect to iTunes screen. Do not release the buttons when you see the Apple logo because you will need to enter recovery mode first. You will then be prompted with the option to Restore or Update. When holding the buttons down it should take around the 20 second mark.
Puan 0
1 Yorum:
I tried it but it doesn’t do anything
tarafından Paylaş
Yorum Ekle
Fix iPhone Stuck In Boot Loop On Apple Logo without losing your files https://youtu.be/0XGMFmHLFCw
Puan 0
Yorum Ekle
To fix iPhone boot loop, this post will be of assistance. I have solved the same problem with the method from it.
Puan 0
Yorum Ekle
My iphone 7 plus boot loop struck iphone logo and computer logo iam not having computer with out computer and laptop repair the phone
Puan 0
Yorum Ekle
Yanıtını ekle
xsulemanhanifx sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 42
Her zaman: 24,334
