Ana içeriğe geç
Repair guides for a large selection of Panasonic digital cameras.
348 Soru Tümünü görüntüle
How to replace lumix DMC-G5 battry door?
Hello,
On my lumix DMC-G5 the battery door is broken.
how do i replace the battery door by myself?
Thanks.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Here's a black replacement part.
Here's the best I found so far on the actual replacement: Panasonic Lumix DMC-G5 Troubleshooting
Do keep in mind that if it's a small part that broke and you (ideally but not necessarily) have all the pieces, you can use plastic welding techniques as well as liquid plastic welding products to repair the part it self. See the last 2-3 paragraphs of this for more information: Which glue will work best to repair plastic dome lid locking part?.
Good luck!
Edit: I forgot to add, if you do end up replacing the part, would you consider documenting the process and adding it as a guide? https://www.ifixit.com/Guide/new/Device/...
Thanks!
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks. i olredy have a new door. how do i remove the old one? i whant to replce the broken door, not to fix it.
tarafından
Yorum Ekle
En Yararlı Yanıt
@avnyhill you remove the rear case to get access to the battery door. Then remove the door shaft that holds the spring in place. Check for the orientation of the spring. Like @alphapeaches already mentioned take pictures for a guide and for your own record. You can now remove the door. I attached the disassembly part of the SM for you. It will show you the total disassembly but you can of course skip most of those steps.DMC-G5-Disassembly.pdf
Puan 3
Yorum Ekle
Thanks to @oldturkey03 for the diagram. It’s straightforward enough.
Remove the 6 screws from the sides and underneath, note that the two underneath are shorter.
Remove the two screws under the eyecup and the two silver ones each side of the eyepiece (labelled C in diagram D2) and the back will then come away. I didn’t need to remove any of the ribbon cables as it’s possible to access the battery door without removing the back completely.
The door shaft was a bit tricky to remove, and I kept my thumb over the spring to stop it flying off, but it’s not under any particular tension and so replacing the door and reinserting it was easy.
In the UK the part was available at Spares2Repair, part number ES836511.
Puan 0
Yorum Ekle
Yanıtını ekle
avny sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 8
Her zaman: 995
