Ana içeriğe geç
Announced in August 2017, the Galaxy Note8 is the successor to the recalled Galaxy Note7. The Note8 was made available to the public for purchase in September of 2017.
148 Soru Tümünü görüntüle
Can I replace a broken stylus without opening the case?
Don't know how it happened but I went to remove my stylus and only 1/2 came out! I broke in the middle not at the seam between the body and the head. Thinking about super glue and a strong piece of wire unless someone has a better idea.
Bu iyi bir soru mu?
Puan 0
1 Yorum
Thanks Jim, I had thought about that and wanted to wait to see if anyone came up with a better solution, nobody did so I went ahead and found a #10 2.5" long drywall screw, had to try 3 time before I got a good enough grip then POP it came right out! Thanks!
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
You could try screwing a long screw into the broken stylus just enough to grab hold and pull out
Bu yanıt yardımcı oldu mu?
Puan 3
Yorum Ekle
I took a drill bit and a dab of super glue. Make sure its completely dried b4 putting the pen back. Good luck.
Puan 0
Yorum Ekle
Yanıtını ekle
Don Gockel sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 5
Her zaman: 1,000
