Ana içeriğe geç
Repair and support for ceiling-mounted bladed fans.
Ceiling fan not responding to remote control
Grandson played with remote control, with a finger on each of the hi & low speed buttons simulataneously, jiggling them. Fan now only runs at high speed & does not respond to medium or low speed buttons. Have replaced battery.
Update (12/26/2017)
The make is Lucci air On the back of the remote is the number FCCID CHQ 70307
Bu iyi bir soru mu?
Puan 1
3 Yorum
where is the controller?
tarafından
The fan stopped working despite completely working remote and fan able to respond with the main switch
tarafından
@aryaan
What is the make and model number of the fan?
tarafından
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Have a look on the control for a reset switch (hole). If present reset controller. Otherwise post make and I'm sure someone will know if there is a button code to use.
Bu yanıt yardımcı oldu mu?
Puan 0
3 Yorum:
My remote will not turn off light or fan off or do any speed changes
tarafından
@geoffwilli12388
Do the control switches for the fan work OK? Most remote controlled fans also have manual on/off/speed switches wired to them as well.
tarafından
I have tried fitting new battery.
tarafından
Yorum Ekle
En Yararlı Yanıt
Hi @chandrakathy,
Mostly the controller (receiver) is located in the housing of the ceiling fan.
Disconnect the power for the fan by removing the fuse in the power box and then access the ceiling fan housing.
Be safety aware you will be working with lethal voltage circuits! If there is no separate fuse marked for the fan then perhaps it is connected in with the lights fuse. If the fan was not working at all so that you can’t verify that it has no power connected by trying to turn it on and off after having removed the fuse, then take no chances and operate the house main power isolating switch or remove all the main household side power and light supply fuses in the power box. If in any doubt contact an electrician. It’s not worth doing it yourself, your life is worth more.
You don’t state the make and model but there are normally some screws that can be undone to access the wiring etc.
Here’s the ifixit Ceiling Fan Light Fixture Replacement guide.
The images shown at Step.2 in the guide (hover mouse over right side image) give you a rough idea where to look for the controller.
Puan 1
Yorum Ekle
If your ceiling fan has stopped working, there are a few possible reasons why. First, check to make sure that the power is turned on at the circuit breaker. If the power is off, flip the breaker switch to the on position and see if the fan starts working. If the power is on and the fan still isn't working, it's likely that a fuse has blown or there is a loose wire. Check the fuse box and replace any blown fuses. If there are loose wires, tighten them with a screwdriver. If none of these solutions work, you may need to call an electrician. learn more ceiling fan solutions here
Puan 0
1 Yorum:
My fan is not working
tarafından
Yorum Ekle
Yanıtını ekle
Carmen sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 13
Son 7 gün: 67
Son 30 gün: 443
Her zaman: 42,663
