Ana içeriğe geç
Motorola G5s Plus, XT1804 model numarasıyla (ülkeye göre değişiklik gösterir) tanımlanabilir. Motorola'nın Moto G serisinin 5. neslinin güncellenmiş bir versiyonudur. Bu cihazın ayırt edici özelliklerinden bazıları metal unibody tasarımı, iyileştirilmiş ön ve arka kameraları ve daha büyük bataryasıdır.
Not phone network signal
My g5s plus drop in the water, after that not have signal gsm, the SIM is recognized (ask the pin and shows the company name of the sim) but can't search phone networks, when I try scanning appears error network. How can know if the problem is the signal cable was disconnect or the motherboard phone?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
3 Cevap
Filtre ölçütü:
Seçilen Çözüm
Hi @lipebu78 ,
Water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the phone's operating design and could damage the components.
First do not turn on your phone and then you need to with the phone turned off, remove the battery as soon as possible from the phone to minimize further damage.''
Then you need to dis-assemble the rest of the phone and clean all the affected parts using IPA 90%+ (Isopropyl Alcohol, available from most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% or less, may contain scents and is not as effective. If you do check the label to verify the amount
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the phone might possibly work correctly again.
Here is a link to the ifixit Moto G5s Plus Repair guide(s) for your phone which may be of some help.
If this process seems too daunting, take your phone to a reputable, professional phone repair service experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
1. If you don't turn it off and clean the water in time, maybe the signal cable has been water damaged.
2. Remove the signal cable and reinstall it, test whether it is normal or not.
3. You can tear it down and check whether the signal cable is loosen or not.
4. If the methods above can’t fix the signal problem, then you should turn to the hardware solution: change a new signal cable. We have provided how to replace the Moto G5s Plus signal cable repair guide for you.
Puan 0
Yorum Ekle
this situations very commune want to upgrade or downgrade the so, its very easy just fix the partition efs
Puan 0
Yorum Ekle
Yanıtını ekle
Felipe sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 11
Son 30 gün: 38
Her zaman: 7,014
