Ana içeriğe geç
Model numarası RCT6773W22 olan, 2014 yılında piyasaya sürülen 7 inçlik RCA tablet için cihaz onarımı ve sorun giderme.
white screen with black lines
My daughter dropped her RCA tablet. It worked fine for over an hour. Then started showing a white screen with black and gray lines across it. I tried resetting it. And turning it off. How can we fix it. Please she's very upset
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 2
1 Yorum
How to fix a white screen on my rca tablet
tarafından
Yorum Ekle
2 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi @momma3 ,
Either the screen's video cable has come loose or the screen is faulty and needs to be replaced.
Here is a link that shows how to replace the digitizer in your tablet. It is useful as it shows how to open the tablet so that you can check if the video cable is seated correctly into the systemboard and then if it is OK, how to continue to dis-assemble the tablet to gain access to the LCD screen..
If you decide to open the tablet to investigate and / or to replace the LCD screen, be sure that you disconnect the battery from the systemboard first (3:20 minutes into the video) before proceeding any further with the repair.
Here is a link to a supplier of the LCD screen replacement part. It is not a recommendation to use them. It is shown to give you an idea of the cost of the part. There are other suppliers online that may suit you better. Just search for RCT6773W22 lcd screen part for results.
If you find this too daunting then I suggest that you contact a reputable, professional mobile phone repair service and ask for a quote to repair the tablet. You already know the cost of the part. ;-)
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Try opening up the tablet, if it is possible the video cord on the inside needs to be tightened I had the same problem too.
Puan 0
Yorum Ekle
Yanıtını ekle
Heather sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 4,087
