Ana içeriğe geç
4-inch iPhone released in March 2016 with similar hardware specifications to the 6S. Available in Silver, Space Grey, Gold, or Rose Gold with 16/32/64/128 GB storage options. Model: A1662 and A1723
1049 Soru Tümünü görüntüle
iPhone SE completely dead
My iPhone SE has gone completely dead. The display is unresponsive, my computer registers nothing when it's plugged in, and DFU mode didn't help. This happened during a battery replacement, where the phone began to boot before I was ready to put the screen back on. I turned it off, finished screwing everything in, put the display on, and found the phone unresponsive. The battery had charge, and the screen was working. My best guess is a combination of the upper wiring harness going out, and me turning the phone off having caused the need for DFU mode. The flash wasn't turning on before the battery repair, and so I figure the power button must have also died at some point when I was screwing everything in, along with turning the phone back off maybe somehow messing up the OS. However a new harness is going to take a while to ship, so in the meantime, any other ideas?
Also, before writing I did a full disassembly, and at least by my visual inspection everything looked fine.
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
It sounds like the battery was connected when you tried to install the screen. That could be the source of your problem. You should also check to make sure you put the right screws in the right place on the screen bracket. You don't want to mix those up as that can kill the phone.
Bu yanıt yardımcı oldu mu?
Puan 3
1 Yorum:
The display was already plugged in before I put the battery in, so I don't think that was the issue. I could see the screws for the screen bracket being the issue, although I can't check since I took the bracket off trying to diagnose the phone before I made this post. If that was the issue, is there any way the phone can be saved?
tarafından
Yorum Ekle
Yanıtını ekle
Feni sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 16
Her zaman: 1,245
