Ana içeriğe geç
Guides and repair information for assorted graphics cards, also known as video cards, graphics adapters, or display adapters.
97 Soru Tümünü görüntüle
Sapphire Radeon RX 570 8GB burned resistor(?)
Trying to understand what is broken here, so I can replace the parts.. believe it says r200 where the part is burned.
Any help is appreciated :)
My card:
http://oi67.tinypic.com/oqkbyo.jpg
rx580 (same pcb):
https://www.techpowerup.com/reviews/Sapp...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
hmm noone?? :)
tarafından
Yorum Ekle
5 Cevap
Filtre ölçütü:
En Yararlı Yanıt
yes its a resistor with r200 and mr200 written above it but finding the value and package size could be difficult
Bu yanıt yardımcı oldu mu?
Puan 1
6 Yorum:
there seems to be so many different physical sizes for them. and different wattage, etc.
what is the best approach here, do you think?
possible to use different r200s here (with different wattage etc), as long as the physical size fits?
thanks!
tarafından
i would only be guessing as theres no schematic i would probably try 0603
tarafından
most r200 is see are 1w 1% so any resistor around that
tarafından
where i can get that...0603 r200? :)
tarafından
you could probably get them on ebay just type in r200 0603, it will probably not have r200 on the top tho. the thing is how many ohms it will be
tarafından
1 tane daha yorum göster
Yorum Ekle
Graphics card Schematics Sapphire Radeon RX 570/580 https://drive.google.com/file/d/1ylcnbtS...
B200 = R220
Puan 1
Yorum Ekle
That is fuse for +12V supply.
If your fuse burn, you must check short circuit before u replace. I have same problem, the fan not have supply voltage. My fuse is good but the circuit no voltage out to fan.
Is any bodyhave a schematic for shapire rx580.? Please help.
Thx Rico
Puan 0
Yorum Ekle
Just for completion sake. Reference designator R200 is a 20Kohm 5% resistor in what looks to be a 0603 package
Puan 0
Yorum Ekle
I have broken RX570 4GB (ROG-STRIX-RX570-O4G-GAMMING)
4 pcs. Resistors 2.2 ohm near PU800 (7805) linear regulator for 5V is extensive heating, on picture I write resistance and voltage
I do not have expirience to fix this RX card, before i fixed older types cards like (GTX 660, R9 280X, …)
If you can help me please….
Puan 0
Yorum Ekle
Yanıtını ekle
Ole sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 15
Son 30 gün: 66
Her zaman: 3,157
