Ana içeriğe geç
Guides and repair information for assorted graphics cards, also known as video cards, graphics adapters, or display adapters.
111 Soru Tümünü görüntüle
Sapphire Radeon RX 570 8GB burned resistor(?)
Trying to understand what is broken here, so I can replace the parts.. believe it says r200 where the part is burned.
Any help is appreciated :)
My card:
http://oi67.tinypic.com/oqkbyo.jpg
rx580 (same pcb):
https://www.techpowerup.com/reviews/Sapp...
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
1 Yorum
hmm noone?? :)
tarafından
Yorum Ekle
4 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Graphics card Schematics Sapphire Radeon RX 570/580 https://drive.google.com/file/d/1ylcnbtS...
B200 = R220
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
its not the same
tarafından
Yorum Ekle
yes its a resistor with r200 and mr200 written above it but finding the value and package size could be difficult
Puan 1
6 Yorum:
there seems to be so many different physical sizes for them. and different wattage, etc.
what is the best approach here, do you think?
possible to use different r200s here (with different wattage etc), as long as the physical size fits?
thanks!
tarafından
i would only be guessing as theres no schematic i would probably try 0603
tarafından
most r200 is see are 1w 1% so any resistor around that
tarafından
where i can get that...0603 r200? :)
tarafından
you could probably get them on ebay just type in r200 0603, it will probably not have r200 on the top tho. the thing is how many ohms it will be
tarafından
1 tane daha yorum göster
Yorum Ekle
That is fuse for +12V supply.
If your fuse burn, you must check short circuit before u replace. I have same problem, the fan not have supply voltage. My fuse is good but the circuit no voltage out to fan.
Is any bodyhave a schematic for shapire rx580.? Please help.
Thx Rico
Puan 0
1 Yorum:
@hendricorico no, it is not a fuse.
tarafından
Yorum Ekle
@xuw here it is almost 6 years later and I am certain you have replaced your video card by now. Just for completion sake, check the reference designator on the PCB
. It says B200 and MB200, so it is not a resistor. It is a ferrite chip bead inductor. In this case it has a impedance of 220 Ohm 2500mA 25% in a 0603 package
Puan 0
Yorum Ekle
Yanıtını ekle
Ole sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 42
Her zaman: 3,495
