Ana içeriğe geç
25 Eylül 2015'te yayımlandı. A1688/1633 modeli. Bu cihazın tamiri eski nesillerinkine benzer; tornavida ve kaldırma aletleri gerektirir. GSM ya da CMDA olarak / 16, 32, 64 yada 128 GB kapasiteli / Gümüş, Altın, Uzay Grisi yada Rose Gold (Gül Altın) seçenekleri mevcuttur.
Proximity and ambient light sensor
Hi everyone, I have a problem with the proximity sensor and the ambient light sensor of my white iphone 6s. I replaced the front panel with a non-OEM part. at first the proximity sensor did not work. with an indelible marker I obscured the sensor housing and worked. if I make a call and then put the phone to my ear, the display goes off. if I receive a call and the phone is on the table, when I put it to the ear the display goes off. if instead I receive a call and take the phone out of my pocket and put it to my ear, the display will not turn off. I did a test: if I receive a call and I cover the proximity sensor before answering, the display will not turn off. if, however, I cover the ambient light sensor before answering, the display on call will turn off. if I receive a call and the phone is in my pocket, I answer, press the home button and then return to the call, the display if I put the phone to my ear, goes off. what could be the defect? thank you all
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
2 Cevap
Filtre ölçütü:
Seçilen Çözüm
Did the replacement screen come with the Front Camera Sensor flex pre-installed? If so, those usually contain a lower quality aftermarket flex and can be the root of your issue. In that case, I would recommend you transfer over the original flex from your damaged screen, following this guide.
If you did migrate your original flex, then tale a closer look at it to see if the flex was damaged, such as a tear or broken connector pin).
Update (05/24/2018)
Hi @refectio
the screen arrived without flex. the sensors are original apple. in these two days I disassembled and reassembled the flex several times, placing the sensors in the correct position. The sensors are clean
Bu yanıt yardımcı oldu mu?
Puan 1
Yorum Ekle
Hi, some news: if I leave the phone with the display facing down and someone calls me, if I put the phone to the ear, the display doesn't turn off. But if I put the proximity sensor on the surface where the phone was first, the display goes off.
Puan 0
Yorum Ekle
Yanıtını ekle
Vito Gravante sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 9
Her zaman: 2,896
