Ana içeriğe geç
The Cuisinart DLC-8F has only two controls, On and Pulse/Off. Also referred to as a Custom 11 or Deluxe 11.
4 Soru Tümünü görüntüle
Motor post cover cracked
Can the motor post cover be replaced?
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 5
3 Yorum
So over a year ago and no answer...the motor post cover is what just cracked on mine! What I assume the motor post is is the post that comes up through the processor bowl in the center...it' the post to the motor, sorry not able to post photos. There is a plastic cover that covers that post and it formed to be able to fit the S blade or whatever blade you are using over it...THAT plastic formed cover on the motor post has cracked. Can it be replaced???
tarafından
On the older quality machines, you cannot repair the post. what I did was to glue the pieces bag together with very specific plastic glue and that has worked for quite a few years.
tarafından
Thanks for the reply D S. I have it taped at the moment but will look for some plastic glue.
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
Not quite sure what you are referring to.
Post some close up pictures of what you mean.
Here's how Adding images to an existing question
Are you referring to the stem that holds the blades?
If it is the blade stem then here’s a link to a supplier of the part.
Be aware of the warning given with the part:
“If you are replacing parts for older Cuisinart machines, you may have had discs that each had their own stems.Cuisinart no longer manufactures the discs and stems attached.You must now purchase those two parts separately.“
Bu yanıt yardımcı oldu mu?
Puan 2
Yorum Ekle
Yanıtını ekle
darnbunnies sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 15
Her zaman: 861
