Ana içeriğe geç
Plastic seating devices for patios, poolsides and bachelor pads.
3 Soru Tümünü görüntüle
Damage to clear chair
There was a number written on bottom of clear acrylic chair I purchased. I tried to remove it first with glass cleaner. No luck. Then I used nail polish remover. It removed writing (looked like black sharpie) but left area foggy, no longer clear. How can I restore?
Bu iyi bir soru mu?
Puan 0
Yorum Ekle
4 Cevap
Filtre ölçütü:
Seçilen Çözüm
Nail polish remover generally contains acetone or ethyl acetate both of which dissolve plastic. You could possibly buff it out but you are going to make a much larger area involved. IMHO further repair attempts are going to be futile. Live with it.
Bu yanıt yardımcı oldu mu?
Puan 5
Yorum Ekle
Lookup a technique called "chemical polishing". It uses a solvent of the material and a way of "rolling" the papertowel / rag so only fresh solvent is wiping the surface. I do it on car headlight lenses, but it took a fair amount of practice. I use a liquid acrylic glue, but straight acetone should work.
Puan 1
Yorum Ekle
Paint Thinner - oil based, great discoloration remover and will make the PVC or plastic shine - use dawn dish detergent to clean the oily residue after you remove all the stains.
Puan 1
Yorum Ekle
Next time try ISO alcohol. I find it removes permanent marker ink.
Puan 0
Yorum Ekle
Yanıtını ekle
Marilyn Hartley sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 9
Son 7 gün: 28
Son 30 gün: 86
Her zaman: 1,704
