Swiping up, down, left, right all work. Touch does not work.
Ifixit screen 1
Ipad Original Motherboard
Ifixit screen 2
Original iPad Screen
After replacing screen, cannot select anything with touch. I can swipe but touch does not work to select anything. This is the second screen I have put in. The first only half the screen worked. This is the second screen. When I reinstall cracked original screen it works fine. Any ideas. the cables do not snap in place the same way as the original. They seem not to snap. They appear to be connected but will come off very easily.
Bu iyi bir soru mu?
7 Yorum
Does the screen need to be physically attached to the base in order for the touch to operate correctly?
Michael Simonello tarafından
Michael Simonello no it does not. It will have to be properly connected to the logicboard but you can try its function even if it is not quite assembled.
You can move your screen in all directions but you can not choose the icon to open?
oldturkey03 tarafından
That is correct. I cannot select any icon. I cannot swipe to power off. I can move the screen left right up down by swiping the screen.
I also noticed that if in camera screen if i touch an area on the screen the camera focuses to that area. So something is noticing where I touch but has no effect on icons.
That is correct. I can move screen in all directions but cannot select any icon. I cannot also swipe to power off.
So it’s responding to the slide of your finger but not the tap of your finger, correct? When you turn on the device are you unlocking it with your thumbprint?
Blaked89 tarafından
2 tane daha yorum göster
