Ana içeriğe geç
Smart fitness watch via Bluetooth, released in March 2016. Model: FB502SBUL
Fitbit accidentally dropped into water
I've accidentally dropped my Fitbit Blaze into water few week ago, then when i was trying to power charge but it's not working properly. May I know where should I send my fitbit for repair? My location is at Penang, Malaysia. Please reply asap. Thank you.
Bu soruyu yanıtla Ben de bu sorunu yaşıyorum
Bu iyi bir soru mu?
Puan 1
Yorum Ekle
1 Cevap
Filtre ölçütü:
En Yararlı Yanıt
Hi,
You may be able to fix it yourself.
As you know water and electronics and electricity are not a good mix.
The water causes corrosion and provides circuit paths for the electricity which were not in the watch’s operating design and could damage the components.
First remove the battery as soon as possible from the watch to minimize any further damage.''
Then you need to dis-assemble the rest of the watch and clean all the affected parts using Isopropyl Alcohol 90%+ (available at most pharmacies) to remove all traces of corrosion and water. Do not use "rubbing alcohol" as in some cases this is only 70% IPA or less, can contain scents and other ingredients and is not as effective. If you do check the label to verify the amount of IPA
Here is a link that describes the process.
Electronics Water Damage
As always with electronics, especially surface mounted PCBs be gentle when handling and especially when brushing away the corrosion. You do not want to remove any components from the board.
Hopefully after you have done all this the watch might possibly work correctly again.
Here is a link to the ifixit guide(s) for repairing your watch.
Fitbit Blaze
If this process seems too daunting, take your watch to a reputable, professional electronics or mobile phone repair service, experienced in water damage repair and ask for a quote for a repair. If you decide to do this, do it sooner than later.
Bu yanıt yardımcı oldu mu?
Puan 2
2 Yorum:
Hi, I have tried all the methods you gave me but my fitbit is still not functioning, unable to charge. Please help on this.
tarafından
Hi,
The damage may have been more severe than hoped.
You most probably will have to get it assessed by a reputable, professional electronics repair service as to what the problems are and then decide if you're prepared to pay the cost of the repair, if it can be repaired that is.
tarafından
Yorum Ekle
Yanıtını ekle
stephylicious916 sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 507
