Ana içeriğe geç
Fingerprint will not work
Replaced screen and digitizer
evrrything works except the fingerprint
mid this my fault or is my replacement screen and digitizer not compatible
Bu iyi bir soru mu?
Puan 0
1 Yorum
So the home button works perfectly how is I did not impair it’s function
tarafından
Yorum Ekle
1 Cevap
Filtre ölçütü:
Seçilen Çözüm
You may have accidentally damaged the Home Button Flex (the actual home button) or the Home Button Link Flex (a long flat cable that runs underneath the LCD Heat Shield). Take a look at this guide and double check your work. It’s not uncommon to tear the HB flex as it is very fragile and it will tear if it’s forced in any way. The other possibility is the Link flex and the connector at the end of it. Sometimes people accidentally pierce through it while trying to disconnect the HB from it and lifting iff the screen frame.
If the actual Home Button is damaged, there is nothing you can do, only Apple can replace it.
Bu yanıt yardımcı oldu mu?
Puan 2
1 Yorum:
Thanks @jayeff , all fixed now :>).
tarafından
Yorum Ekle
Yanıtını ekle
Timothy Young sonsuza kadar minnettar olacak.
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 77
